time2roll
Mar 10, 2021Nomad
Yosemite Sam1 wrote:Depends on the controller. Mine very specifically says to always have a battery connected before solar power is connected.Housted wrote:What could possibly happen?
A word of caution here:
Most if not all solar controllers do not want solar connected without battery connection first. Be very careful when switching between batteries on the output of solar controller. You might want to add a breaker/switch to the solar input to the controller. You can then disconnect the solar panels and do your battery reconfiguration to charge the TM battery.
Because this is my situation every time I take out my solar panels out of it's box and RV storage.
The solar panels are pre-connected to the controller, gets exposed to the sun as I set it up -- and before it gets connected to the batteries, the last step of the connection processes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
