haste_maker's avatar
haste_maker
Explorer II
Mar 04, 2020
Class A LP Tank
I am thinking about trying to put a "T" in my LP line @ the LP tank, has anyone else done this on a Class A ? If so did you have problems doing this ?
  • fyrflie wrote:
    If you prefer low pressure, make sure that none of your appliances (i.e. Firepit, BBQ, Etc.) do not have a regulator attached.
    Propane does not like to be double regulated.
    Look closely at the propane regulator on your RV. It is a two stage regulator. Then on the propane stove in your RV is a third regulator.
    Richard
  • If you prefer low pressure, make sure that none of your appliances (i.e. Firepit, BBQ, Etc.) do not have a regulator attached.
  • Low pressure to use outdoor grill & fire pit...shut off is a good idea...thanks
  • You want high pressure? or low pressure? If you want high pressure you can either add a tee and a couple nipples by removing the POL fitting. Low pressure you can tee in anywhere downstream of the regulator. I would highly recommend that you add a shut off at your tee for your branch line.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
