Almot
Jul 11, 2018Explorer III
Itinerant1 wrote:
What voltage are you calling 100%, 85-90%?
Are you saying if charging with solar you would charge to 85-90% then stop charging and run off the battery cycling it while the sun is up and could be powering misc items?
Whatever the manufacturer says the voltage is at 85, 90, or 100%.
90% is easier to determine with battery monitor, not a voltmeter, because in Li it's almost flat at this point.
Yes, it's better not to let it go higher than 90%. Can be done by terminating the charger input to battery, or by running the loads. Ideally, Li charger should be able to be programmed accurately to achieve this.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
