Itinerant1
Jul 13, 2018Explorer
*Elite-GBS 500ah 12v lithium batteries package
EMS Sense Board(s)
1- EMS CPU with Custom RV Programming
1- CPU Harness Cable
1- 500 Amp 50mv Shunt
2- 400 Amp Solenoids, high efficiency coil
1- 7” TFT LCD Video Display
1- Video Extension Cable
1- lot Fuses, Fuse holder, Switches, Connectors
1- System Control Panel, Wiring Diagram, Photos, Manuals, Safety Information
*8 CTI 160 watt panels_ 2 in series, 4 sets parallel (flat mounted) to junction box
*Magnum PT100 controller
*Magnum 3012 hybrid inverter with ME-ARC 50
*100amp AC sub panel - everything in the 5th wheel except the water heater is running through the inverter.
*10/2, 8/2, 6/2 wire, 3/0 cable
*Manual trip 48v DC breakers - 50a (solar in), 120a (solar out)
The 2 display (this was using microwave, fridge, misc item), 7" display showing battery info/ 20 cells info
EMS Sense Board(s)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
