Mako_Kupo
Jul 13, 2018Explorer
itinerant - I don't think I'm comfortable building a battery, so thats pretty much out unless I find someone locally to help me do it. to me, there is no debate between PWM and MPPT. I have both on my goal zero unit, and I have many, many times, tried out each one and not one time did the Pwm do better. the Pam beats it every single time, and I can literally unplug and plug in my solar panels in 1 second to test it. right now, I am getting 60w through my mppt. I unplugged it and plugged it into the ppm, and a getting 55. the discrepancy is usually much bigger than that though.
basically, I am not even considering PWM controllers. they are ancient relics! not really, but why tread backwards?
so you recommend building a system out of parts made by the same company then if possible? as in, buy everything made by Victron or whoever, instead of mixing parts. I do not want to find myself in a situation where a couple hundred dollars more would make a huge difference. might it be smart to sacrifice 100-200 AH to improve elsewhere? my wiring is all sufficient(did it myself), so that doesn't need any upgrading whatsoever.
my budget is around 10k.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
