Mako_Kupo
Sep 16, 2018Explorer
hey i am back. many things happened to postpone this, but its time. i am going with 2x 300ah lifeblue lifpo4 batteries. i will be starting by only charging them via alternator, then in about a month ill get the solar controller. i figure this - lithium can take so many amps, that i should only need to run the camper for a relatively short time to charge them up, 15-30 minutes idling camper should provide a pretty decent charge. what i need from you guys, is a list of what i need, please!! everything i learned before has pretty much been forgotten.
what i know i need:
batteries
charger/inverter from magnum(3000w hybrid)
-this will allow me to both charge the batteries via shore power, and to use the power generated from them. it is both an inverter and AC-DC converter that charges the batteries.
i need to know everything else. i believe there is a system made by blue seas that will allow me to control the voltage from the alternator, and stop them from over charging. aside form that, i know nothing. thank you all so much!
what i know i need:
batteries
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
