Itinerant1
Sep 22, 2018Explorer
Other than the air conditioner if needed I'll hookup the generator (only needed it twice). The hot water tank isn't wired through the inverter but if it was it would not be an issue. Everything else I have no problem using including hair dryer,sm. shop vac, small air compressor,even today I have the car battery charger hooked up to a lead battery giving it a full charge (7am started charging still). Having 1,280w solar doesn't hurt.
Here is a current recorded display reading scroll down to yesterday. Early morning 38% SOC making 2nd pot of coffee using microwave for breakfast at the same time (2,800w) end of day 97% SOC. Loving the Lifepo4/ solar.
DC display readings
DC display readings
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
