Itinerant1
Oct 23, 2018Explorer
Mako I'm guessing you figured it out but right now you're running solar panels 800w @ 12v in some configuration. If you haven't series these you're looking at 16+v then adding amps, now going to a 24v battery system you're going to need to series the panels to double you voltage for charging. So something like 2 sets of 100w, 1 set 150w, 1 set 50w then parallel at combiner box. So the v doubles per panel set with the amps remaining the same. Amps total together after combiner. I forgot to look are you using an mppt controller?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
