mmccwill
Apr 04, 2016Explorer
The one`s I`ve done had 4 slides -- I prefer to use the most plush carpet that will work, because it looks & feels better- You have to remove the bed, couches & such -- Most of the time, you find other problems once the carpet is removed that needs repaired or adjusted -- I always work by myself, & that`s why it usually takes about 40 hours to do a good job -- Labor on a 40/42 footer runs from $1000.00/ $1200.00 --- Bill Willard
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
