BarneyS
Jul 14, 2020Nomad
Here is your picture. I think I would run a garden type hose from the sink to the washout port of the tank (small opening up near the handle with a cap). When ready to dump it, just unscrew the hose, put the cap on the port, take to dump station and hook a regular dump hose from the tank (large port) to the dump hole.
Grey water can and often does smell just as bad or worse than the black tank. I would not run it on the ground unless camped alone in a large remote area. Your neighbors will not like you one bit if you run it on the ground. It is illegal, as far as I know, to do that in any state campground and most private ones. If you leave the caps on until ready to dump there should be no smell problem in the camper.
Barney
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
