DownTheAvenue wrote:
With two leads (one positive and one negative) coming off the controller, can I just hook one lead to one battery on the appropriate post, and the other lead on the other appropriate battery post?
Yes, but... A proper "balanced wiring" is when one lead goes to + on one battery, and another lead to (-) on ANOTHER battery. The loads should also be wired to +/- of two different batteries.
On a perfect day with no clouds and no shade 100W suitcase will harvest just enough for a die-hard minimalist to bring battery back to 99.9% in the evening. 200W flat on the roof would harvest more, in the same sun conditions.
Tilt doesn't matter (much) in summer and in the South where you are. Following the sun... Averagely lazy user changes the azimuth 2 times a day or less, this won't make much difference.
Saving money on $6 tube of sealant (with suitcase) - let's not go there... Solar suitcases cost over $2 per watt, while permanent installs cost less than $1.50 including all.
Connection of off-the-shelf suitcase to coach battery is a so-so, usually a pair of crocodiles of poor quality steel. Not very safe. Or via 12V cig lighter receptacle of the van (transitioned via non-waterproof SAE if they bothered to include one), if your receptacle remains hot with the ignition off. Unless your van has a dedicated exterior 12V receptacle specifically for this purpose.
Controller that you don't need to bring inside... Keep in mind that it is not waterproof.
Holes in the roof (for permanent system)... Depends on how old the van is. Doesn't matter after some time.
No installation required (for portable)... True, but dealing with portable will take much more of your time if you move around often.
On the "bright" side - pun intended :) - you can have it parked in the shade and keep portable in the sun, if cable length allows. This is about the only advantage (over a permanent install) that looks serious enough to me.
