MikeInOregon
Mar 04, 2017Explorer
rjxj wrote:
Maybe you could use an anderson connector to connect the panels to the controller and have a quick easy way to disconnect.
I also like the convenience of a plug-in connection from the portable panel to the solar controller. I have a 150 watt panel on the roof of the trailer and a 100 watt portable panel. I ran wiring from the solar controller to the underside of the trailer. This wire has an SAE connector to easily connect and disconnect the portable panel.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
