agesilaus
Nov 23, 2020Explorer III
VG1087RVing wrote:
I am looking for feed back from my fellow Roadmasters.
1- Is this even possible?
Why Not?
2- What kind of Hinge should I get?
Either look at the hinges already there and go to your local big box hardware store (Lowes etc) or remove the old ones and use them on the side. I would use a thin metal backer plate on the back side of the door and thru bolt the side hinge.
I would place the side hinges on the front edge of the door so the wind would blow the door shut in case someone forgets to latch it.
3- If i want to try it, maybe first doing it on a used door might be smart, is there a good place to go it used RV parts?
RV Junk yard
ANY HELP Would be great..
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
