CA_Traveler
Nov 23, 2020Explorer III
Roadmaster as in Monaco?
Do you have the clearance to make the change and/or have to modify the door etc?
Is the door structuraly strong enough to make the change for a side mount?
If the latch will work with it's different position relative to the hinges will it provide overall adequate door support when closed under various conditions?
I'm guessing you want a side mount for more vertical clearance? They are great for me when the slides are in but most of the time they are not and the slide outs are over them.
My side opening doors have 2 hinges that can be adjusted to align the door.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
