- RV_CONUSExplorer
RonWSl wrote:
I can't blame you for replacing the rv fridge with a residential - I thought about doing it myself last fall when I had to replace the cooling unit on my Norcold (twice cause the first one was defective). Issue I was running into was finding one that had the correct dimensions so as to avoid any cutting of the cabinets/wood. Any cabinet work in your future on this project?
3/8 inch on each side of the cabinet was trimmed. Nice fit. - RV_CONUSExplorer
Jim-Linda wrote:
Don't know about his, but our Whirlpool drains into a pan under the compressor which evaporates the water, no need to drain outside.
Jim
That's exactly the way it is laid out. - RV_CONUSExplorer
RoyB wrote:
There goes your PROPANE backup...
Interesting, the propane backup went when the two cooling units bit the dust. Again, no worries,,,
The Pink dorm compressor style mini fridge saved the Beer,,,cheers! - RonWSlExplorerI can't blame you for replacing the rv fridge with a residential - I thought about doing it myself last fall when I had to replace the cooling unit on my Norcold (twice cause the first one was defective). Issue I was running into was finding one that had the correct dimensions so as to avoid any cutting of the cabinets/wood. Any cabinet work in your future on this project?
- Jim-LindaExplorer IIDon't know about his, but our Whirlpool drains into a pan under the compressor which evaporates the water, no need to drain outside.
Jim - GordonThreeExplorerMaybe there's a few 100 watts of solar on the roof, who needs propane :)
One thing I'm wondering, residential fridge usually have a timer in them for automatic defrost, which drains the melt water into a pan under the fridge. Will you be adding a drain line to the outdoors, or disabling the timer, or what? - RV_CONUSExplorerNO Worries, That's why wine and generators were invented.
- RoyBExplorer IIIThere goes your PROPANE backup...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
