kohai's avatar
kohai
Cup holder for couch?
I keep thinking of ways to hold a drink for my couch. I have contemplated adding a marine drink holder attached to the wall above the arm of the couch. I have looked at bean bag drink holders. I have looked at the kind that drape over the arm of the couch.
What solutions have you all tried that you liked?
  • If You really want to "Stick " things to an RV Wall I recommend using Shoe Goo! which is a type of GOOP that sticks everything to everything! You can use a small wood screw to hold the item in place while the Goo! Cures! Clean the Surfaces to be stuck together with a little Alcohol...Cheap Vodka works well as it contains no Oil and You can always sip on any that doesn't get used for cleaning!
  • NascarBobnBeth wrote:
    i have a marine style cup holder on the wall next to the couch
    How do you attach it to the wall? They are thin and no substance really.
  • I've been qlooking for the same and decided to try a marine style cupholder. I found one on amazon but have not installed it yet. Will let you know.
  • I replaced the factory couch with reclining theater seats that have built in cup holders in the center. Way more comfortable.
  • We got a couple of IKEA plant stands (they're little folding tables) we can set wherever we need a flat surface. Flexible and easy to stow when the slides come in.
  • I bought, IIRC from CW, a wooden tray with a wire that went in the couch that had a cup holder/s and tray to hold remotes, etc.
    bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
