joelyn's avatar
joelyn
CUTTING A HOLE IN TT DOOR? {{{{{UPDATES}}}}}}
hey, have a TT that has no window in the door just a peep hole. want to install a window and have to cut out a hole in the door for the window. i did get a used slim shade window w/ shade by AP products. any tips or do's and don't from anyone that did this before, before i start this project??? really hate to screw the door up.....i was thinking of using a jig saw with a metal blade to make the cut unless better ideas. thanks.
  • 77rollalong wrote:
    masking tape where you want to put the window , just makes it easier to make lines on, double and triple check the opening matches the window . I find zip disks on the grinder are great for cutting thin metal, and i agree with the other post about using hard wood from skids, had to use some for floor bracing in out rv..
    What is a 'zip disk', I doubt that you mean the old floppy disk replacements.
  • have you asked the manufacturer? does the mfr. still exist? I wouldn't think it would be "dangerous" to modify the door on a TT.
    bumpy
  • masking tape where you want to put the window , just makes it easier to make lines on, double and triple check the opening matches the window . I find zip disks on the grinder are great for cutting thin metal, and i agree with the other post about using hard wood from skids, had to use some for floor bracing in out rv..
  • I'd really be concerned about the structural integrity of the door if you were to cut a hole in it. Doors with windows generally have a frame under the skin with a reinforced "hole" the window sets in and the window's perimeter screws to. You may find nothing but aluminum skin and foam to fasten the window frame to. That said, you could probably insert wood blocking (I'd use oak, old pallets are good sources of strong but ugly oak) between the inner and outer skin. Dig out any foam in the way and apply contact cement (NOT the water based junk) liberally and slide the wood in while the glue is still wet. Make sure the recess for the wood is big enough and don't follow the usual procedure of applying the cement to both surfaces, letting it set up, then trying to slide it in. It will just stop at first touch. This should let you securely mount the window in the door without compromising the strength too much.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
