Has anyone removed old peeling decals and replaced them with new ones on an aluminum sided TT? I would like to try and do it but wasn't sure if it would be a nightmare project to undertake.
It's not a nightmare, but close. The hardest part is removing the old decals without harming the finish. A heat gun, and a plastic scraper will get most of them off, the some Goof-off to clean the remaing adhesive. Placing the new decals can be tricky, but slow and steady will get the job done.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
