RColorado's avatar
RColorado
Solved
Dicor Lap Sealant Question
I need to fill some cracks in the sealant on my roof. I've done this before but can't remember what product to use to clean the area of the cracks before putting new sealant on.
I thought I had used Mineral Spirits (paint thinner) in the past, but the Youtube videos I looked at today only mentioned denatured alcohol.
I've got plenty of paint thinner on hand - will taht work or do I need to buy some denatured alcohol?
Thanks!
  • If you use mineral spirits (paint thinner) you may as well just use WD40. Both leave an oily residue.
    Use alcohol, wax and grease remover (for paint prep), lacquer thinner, brake cleaner, etc. I wouldn’t use anything hotter than those solvents.
  • use white gas, that's what all the dealerships I have talked to around my area use.  so basically Colman camp stove gas.  I did mine and put some in a spray bottle, spray some on wipe it off with a rag wait a few, then do the repairs
    • way2roll's avatar
      way2roll
      Navigator III
      So the new sealant sticks. Putting sealant on dirt/grime/mildew won't seal very well.
  • I usually clean the entire roof and then come back over the seams with alcohol.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,386 PostsLatest Activity: Aug 15, 2025
