Maybe this has been posted here before, but was new to me. Would be great for dry camping without AC power or tent camping. I may make one just to use in the garage in the summer! Bucket air cooler
Swamp coolers tend to work OK in SOME low humidity environments but if you are in a high humidity environment (like in my area) it will just make you feel worse by saturating the warm muggy air..
Just hard to beat refrigerated type A/C which REMOVES moisture while cooling making high temps a bit more comfortable.. and works pretty much anywhere you go.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
