time2roll wrote:
otrfun wrote:
IMO this standard converter is a better match for our battery pack than the single-stage Progressive Dynamic dedicated Lithium 45a converter which produces a constant 14.6v. As per BattleBorn Batteries, if a 14.6v single stage converter is inadvertently left connected to fully-charged LifePo4 batteries for weeks, months at a time it can overcharge the batteries. No such concern with our converter.
I am still concerned about the daily 15 minutes at 14.4 while in storage along with 13.6 continuous seems a bit high from what I read.
According to Battleborn, their LifePo4 batteries can sustain 14.6v for at least several weeks at a time without a problem. Doubt 14.4v for 15 min. is going to be an issue. BB batteries can be floated at 13.6v indefinitely.
If there's still concern, one has the option to set the high voltage charge cut-off in the BMS to any value to want with a DIY build. You could even set it to 13.2v if you like. With good BMS presets, it's almost impossible to damage the battery.
