Old-Biscuit
Apr 19, 2013Explorer III
They are 'portable'....
No need to mount them.
Hook up hose from CG water spigot.......then filter(s)...then water softener...then connect to rig.
Even use set-up to fill fresh water tank.
When you tear down and travel you just cap the ends and store it (if you are going to use at next place). If done with it you drain it and blow it out with air then store.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 16, 2026
