DeWat's avatar
DeWat
Does This Sound Crazy... Water Softener
I would like to put a water softener in my coach sometime this season. The water/sewage service bay is too crowded and not tall enough for a water softener or even water filters. What I am thinking about doing is running a line from the water fill/city water input about 14 feet to a basement bay that has plenty of room for a water softener and water filters, and then back (return) to the location where the current water input connects to the plumbing. I've looked up under the coach, and none of the water lines are visible. My guess is because they run inside the coach to take advantage of the heating. Outside of quicker exposure to freezing temps, is there anything wrong with running a 14-foot line on the undercarriage to connect to a water softener/filter, then return the 14-feet to the plumbing? Are there any other cons that I might be missing? I probably won't do this job myself, but I would like to have a water softener for all incoming water.
  • I think you would do better with filtration than a conventional resin tank. There is going to be a great deal of engineering and difficulty trying to orient a brine tank in the basement. Another issue might be that even if your coach was able to handle the electrical demand of the timer and valve motor, you would need to have a fairly good flow of water available at the softener. All of that would mean you need to be hooked up on a city supply. Depending on the quality of the city supply, you may need no treatment for that. The real killer of this would be having any water supply devices in an unheated bay while parked in below freezing weather.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Jan 08, 2023
