btcruzer's avatar
btcruzer
Dometic refrig. questions
we have what I assume is a 2011 Dometic refrig. as the Rv is a 2011. The fridge is a single door outfit with an inner door on the freezer compartment. It is in a slide-out so the upper vent is in a sidewall rather than the roof. I suspected that this arrangement might not be as effective as a roof vent. The refrigerator is mounted inboard about 10 inches from the wall of the slide. This leaves a "box" behind the fridge that measures about 48 inch high, 20 inch wide, and 10 inch deep. The typical vents are located top and bottom of this box. Just above the lower vent a "shelf " is mounted in a half-assed attempt to direct the cooling air past the coils. I had planned to mount fan(s) in the "box" to help with cooling the coils but ran out of time. I did, however, install the little computer type fan inside the fridge.
A recent campout at a racetrack in Nebraska( no connections - no shade ) put this arrangement to the test. It did fare well. The fins in the freezer section iced over but the cooler section did not stay cool enough. We need to store medicine above freezing but below a certain temperature. At times the cooler temps. were at the max. allowed.
The fridge has a display panel with LEDs ( from 1 to 5) indicating cooling ranges. we had this set at 5. I just today noticed that the fridge also has a clip-on sensor on the fins in the cooler section. It was mounted at the bottom of the fin. I guess my question is - Would moving the sensor up on the fin have caused the unit to cool the lower part better? Would I have been able to then change the temp selector to maybe 4 LEDs and keep the freezer fins from icing up? Remember, I had the small fan circulating the air in the lower section.
  • If you have that much open space behind the refrigerator, it is going to give you grief when it gets hot out. Check this Dometic Venting PDF for suggestions on fixing the problem.
  • Take the top vent off the out side and see if the top of the air vent area is square or has a curve to it at the top. If no curve I'd make a curve with some thin sheet metal and install a few computer fans in the top vent to draw air up the back on the refrig. coils and out the top.
    You can pick up 12volts for the fans at the back of the refrig. and just use an on/off switch or put in an inline thermostat. Just be sure to install an inline fuse either way.
  • Try setting it at 3. Sometimes the highest (lower Temp) creates a problem..same with the A/C unit. I have found the mid range settings to work the best.
    Fans at the rear of the fridge will help.
    Make sure you have an accurate thermometer to measure the temp. Temp will vary throughout the day as the sun heats up the side where the fridge is.
    We have a side by side Dometic and the temp usually stays around 35-38 but will go as high as 48 in 80 plus heat with the sun shining on the sidewall where the fridge is located. Ours is vented through the roof with no fans.
    Our coolest shelf is the top one in the fridge. The bottom and door shelves are the warmest area. So try moving the thermometer around to find the coolest spot for the meds.
    You could add dry ice in a container near the meds in the fridge to help keep the meds cooler.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
