- rickhiseExplorerGot it fixed I had to disconnect the water line to relieve
the pressure. Was able to compress it enough
With long nose pliers - SidecarFlipExplorer IIIBiscuit to the rescue....
- Old-BiscuitExplorer IIIRemove pedal cover....using a flat bar compress water valve stem and insert the dome cap
Pg 3-4
http://manuals.adventurerv.net/Dometic-Traveler-Lite-600344934-Toilet-210-owners-manual.pdf
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
