ernie1
Nov 14, 2018Explorer II
I added Drain Master valves to my rv a couple years ago and have found them to be working perfectly and with plenty of power. This version has the metal gears. Are the earlier versions more problem prone? I try to keep the valve blade area cleaned and lubed as often as I can.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
