RollandB
Feb 21, 2017Explorer
Check out KV8400RV drawer slides from woodworkers hardware. Full extension, 100# slides made for RV's. I installed them in an older fifth wheel and never regretted it. You will need 1/2" clearance between the drawer and face frame opening as mentioned on each side. How these work is there is a bit of a catch that holds them shut. When you pull them open it will take a bit more effort.
FWIW, I doubt any HD or Lowes carries them, my local one didn't. Now you can check a stores inventory online so you might bring it up, put in KV8400RV and see if you get a hit on their inventory.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
