AdventureCoach's avatar
Aug 06, 2020
Slide "Spacer/Glide" Replacement
Tiffin Allegro RED broken slide "spacer/glide" surface. The plastic piece that the slide rides on when extending or retracting has broken in half and fallen out. There are two of these per slide, only one has broken but if the other one does it will not be good. Local dealer in Mount Vernon WA say they cannot get me in till mid Sept!
Has anyone attempted a DIY replacement of this part? Would you kindly share the procedure?
  • Thanks to all who responded. Part is on order and I understand the procedure to install. thanks!
  • Do you have the replacement Nylon slides? They have 2 round extensions that fit in the Aluminum block they sit on. All you do, is LIFT the extended room up about 1/2 inch to 3/4 inch and slide the Nylon slides in to the 2 recessed holes. Do this with the room not fully extended. About 2 to 4 inches from full extension. Usually Tiffin supplies the complete part----The Aluminum block and the Nylon glides. You do not use the Aluminum block. Lifting up the room and securing it in the raised position is the hard part for Non Service Center replacement. A way to do it is to be on a concrete/Asphalt type surface. Extend the RIGHT side HWH jacks and lift the RV 2 to 4 inches ONLY. Install bracing under the room and SLOWLY have someone manually retract the jacks and as the Motorhome starts down the bracing will keep the room up as the motorhome settles down. DO THIS VERY CAREFULLY AS YOU DO NOT WANT TO DAMAGE THE ROOM. Doug
    PS, Make sure the Air bags are deflated and do NOT start and run the engine when doing this. You do not want the air bags to inflate. If you have a Ford Chassis, then you do not have air bags.
    Our shop,we have a AC lift, that we use to raise slide rooms for these type repairs.
