Crabbypatty
Feb 15, 2021Explorer
I made angle brackets for my 6 panels. Each panel has 4 brackets for 24 holes and 2 brackets for my circuit box. Drill the hole, fill it with dicor lap sealant, add a generous amount of sealant to the bracket and screw it down. Then add sealant on top of the screw and around the bracket. The sealant self levels for a clean finish. Some rvers drill a large hole for the wires to go into the rv. Same deal, generous amount of sealant around that elec box. I ran my wire down the awning arm then drilled into the bay where the controller and on off switch is.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
