wopachop
Dec 31, 2020Explorer
Many of that type of adhesive is activated by pressure. So make sure to press really hard. Also many dont like being applied to cold surface temps. If applying in the winter it helps to clean the surface with alcohol and then warm it up with a blow dryer or heat gun.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
