TF1
May 20, 2017Explorer
One weak link with Husky is a supplied 30 amp breaker. Last month I went to check the level of my trailer and start the fridge in preparation for a trip and the jack was dead. After tracing the wiring I discovered the bad breaker (everything is 3 years old). I went to several places, RV and auto supply, but no luck on a replacement. I googled the thing and replacements are available, but only in large lots from the importer. I replaced the breaker with a fusible link and carry several spare fuses now. Everything works fine, but if I was installing a new one, I'd replace the breaker from the start. I have the 4500 lb. with the remote control which is a very useful device. I can set the level accurately from inside the RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
