popeyemth's avatar
popeyemth
Electric Mods
Added two meters-AC and DC and changed to a digital thermostat .
All info and directions were recieved here on this forum.
Thanks again for all the great folks here!
Moderator edit to re-size picture to forum limit of 640px maximum width.
  • It is a Hunter brand,5+2 day programmable thermostat on sale at Mennards $9.99.
    This is what the back of my factory thermo looked like
    Simple to follow the color code from old to new .
    Literally a 2 min job and tons better.
  • Thank you for sharing, my meters will be on their way soon! Is there a chance you will share the information on the thermostat? I have the Dometic one and it makes me want to scream sometimes. I am in the early stages of researching to replace it and any info you can share would be greatly appreciated.
    Thanks
    Chad
  • popeyemth,
    This is just what I have been wanting and they look great. Thanks for the Ebay links to make it easy.
  • Lspangler wrote:
    Where did you get the meters? Model numbers?
    http://bit.ly/1mAkqNX
    80-500V AC bule LCD Digital Volt Panel Meter Voltmeter for 110V 220v 240v
    http://bit.ly/1mAkux7
    0-19.99V DC Blue LCD Digital Volt Panel Meter Voltmeter 20v for 12v auto car
    Both from eBay $7.00 each delivered
    Box is an outlet extender from any home improvement store $1.50
    I used phone wire as amp draw is to low to measure with most ammeters.
    Good Luck, Mike
  • Thanks
    Ammeters have too wait :)
    Next is remote reading thermometers for the fridge and freezer, then thermostat controlled exhaust fans for the fridge stack.
  • Looks good. You will find they are very usefull. Next you will be adding ammeters.
  • Nice monitors......love being able to see what is real time voltage and that digital t-stat is a great upgrade
    A flat junction box cover plate with just 4 holes in corners is available vs the slotted cover plate
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
