pennstaterv's avatar
pennstaterv
Electric over hydraulic actuator
Looking for anyone who has installed an electric over hydraulic actuator... I am finishing up my disc brake conversion but have a question about the actuator wiring..
I have a Hydrastar actuator with 4 wires ---
yellow wire goes to cold side of breakaway switch
white to ground
blue to brake controller
and black is 12v power for the electric pump
Now, instructions require a 25-40amp 12v source for the black wire... my F350, however, is only fused at 20amps for the trailer plug. I talked with the folks at etrailer and they were surprised to have never heard this issue before.... especially considering I have a very common truck.
Anyone used this set-up without a problem? I am guessing my only other options would be to replace the truck wiring or add a second 12v wire fused higher and run back to my trailer....
  • My actuator was installed in the front compartment of my 5th wheel and 2 feet from my trailer deep cycle battery. I ran the main power wire directly to this battery.
  • The 'trailer battery charge' circuit in my truck panel is fused at 20.
    I attached the HBA16 wiring diagram. It shows connecting to a "25-40amp circuit from tow vehicle". I understand what you are saying, and the trailer battery is part of the circuit for the breakaway switch, but I wouldn't want to rely on the trailer battery for the brakes on a regular basis. Don't trust a trickle charge to keep up with the use of my braking... I believe it has to be powered from the truck alternator via my 7-pin plug.
  • Correct, the trailer battery(s) has to be in the circuit. The power from the truck is only to trickle charge the battery, if the breakaway switch is operated, the power to either drive the hydraulic pump or engage the electric brakes comes from the battery.
    You do have a battery on the trailer, right? I would think the breakaway switch wiring would be wired into the battery today and would stay that way.
  • I think the charge wire coming from your truck is fused at 40A.
    The lighting circuits are fused at 15~20 amps.
    You can wire the pump to the on-board battery and since the pump doesn't take that much power all the time, the trucks charge wire will keep the trailer battery happy.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
