ktmrfs
Sep 17, 2019Explorer III
ScottG wrote:
Too weak to have any effect at all. I recommend you save your money.
agreed. if you have a humidity issue you likely will need to remove at least a few gallons of water/day. the device you mention is likely a peltier device, lucky to remove a cup of water/day.
Go to a big box store and look for a portable compressor driven unit. small ones hold 3-5 gallons have an external drain. Now, they will draw about 1-2A on 120V when running, 1A is about 120Watts, so at $.10/kwh, it will cost about 10-20 cents/day to run it for 8hrs/day.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
