riven1950
Sep 17, 2019Explorer
DFord wrote:
Dehumidifiers are commonly rated in "pints per day"
At only 20watts, I'd doubt if it could remove a pint in 24 hours.
How about sharing the brand and model of what you're looking at and we can give you a much better idea of what it can do and what you can expect. Without that information we're all just wasting our time guessing.
Ok, here goes: humidifier
I don't plan on using this as a whole house unit. A/C seems to take care of that. Also, the TT has 2 max air vent covers and I leave the vents open 24/7 and we have not had a problem.
Where I planned to use this unit is in my workshop / storage area under the house ( house on pilings ). It is approx 12x14. There is no standing water issue outside, it is built on slab, no leaks. Just trying to eliminate a musky smell / dampness that I think comes because the room is closed up 95% of the time. No window. No A/C, just portable heater.
BTW My man cave is adjacent to this space and same size. Small pool table. It has a window A/C /heat pump. It is used much more often and there is no musky smell there unless it is closed up for a week or so. I also have an exhaust fan I run there at times for air exchange.
So there it is, you wanted more info. What do you think?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
