DFord
Oct 22, 2019Explorer
Humidity is always "relative" to the temperature. As air is cooled, it can't hold as much moisture as it did when it was warmer. Conversely, as cool air is warmed up, it can hold more moisture. It's relative humidity goes down as it's warmed up as long as more moisture isn't added.
With that background, you can understand that bringing in cold outside air into your house in the winter lowers the relative humidity indoors. It gets as dry as a dessert making static electricity a problem. Dehumidifiers shouldn't be needed in the winter unless your space is really tight and no "infiltration" occurs.
Example:
If you bring in 35 degree air at 100%RH, and warm it up. it becomes 70 degree air at 29%RH.
Example:
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
