jseyfert3
Oct 23, 2019Explorer
DFord wrote:
Humidity is always "relative" to the temperature. As air is cooled, it can't hold as much moisture as it did when it was warmer. Conversely, as cool air is warmed up, it can hold more moisture. It's relative humidity goes down as it's warmed up as long as more moisture isn't added.
With that background, you can understand that bringing in cold outside air into your house in the winter lowers the relative humidity indoors. It gets as dry as a dessert making static electricity a problem. Dehumidifiers shouldn't be needed in the winter unless your space is really tight and no "infiltration" occurs.
Example:
If you bring in 35 degree air at 100%RH, and warm it up. it becomes 70 degree air at 29%RH.
Seems like you're referring to me, though I'm not certain it's in regards to the dehumidifier in the basement or the dehumidifier I just bought for our RV.
For the RV, I got it because our unit is pretty sealed (2015 Rockwood Mini Lite 2306). Too sealed, perhaps. We do run the roof vent while showering with the window in the bathroom open and the vent fan while cooking, but still, water starts condensing, mostly on the single pane windows but also above the bunks, behind the bed, in the cupboards or anywhere that's cool with low air circulation. Our last camping trip it was about 45 °F during the day and 35 °F at night. It rained most of the time, so the outside humidity was 100%. We had a lot of condensation inside the camper.
I do understand relative humility, but that last trip if you run the calculation from 100% at 45 °F it's 50% at 65 °F, where we kept the camper. Much better, but not great when you have a wet shower and you're running the oven to cook dinner. Plus it's cold to vent a lot of air. Hence the dehumidifier.
I'm also planning on making a DIY air/air heat exchanger like the one RickW made on this site in 2012. Even though I can't see Rick's pictures, I got a good enough understanding from reading, the pictures from a user later in the thread, and general understanding of heat exchangers. This will be for venting for humidity, cooking/showering, and general fresh air when it's cold out. Obviously it's much easier to bring in fresh air when you can recover 75% of the heat of the air that's leaving.
EDIT: Described the removed link. Odd the forum is set to purge links to itself for new members, but okay. Likely nobody thought to whitelist this site in the auto-filter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
