GordonThree
May 12, 2015Explorer
skripo wrote:
When I purchased my trailer the manufacturer had put a household junction box near the battery.
2 wires went to the battery and all the other wires where connected together with twist on wire connectors. The dealer added a fuse on the battery power line, dropping 2 steps of wire thickness to do it.
I myself added something and now it is now a big corroded mess. I've lost power and want to redo the whole thing properly.
I am looking for a buss bar or connection box to bring it all together but found nothing other than a DIY solution consisting of a water proof junction box and 2 bus bars. I don't like this solution.
Is there a nice junction box specifically made for connecting a DC battery to several thick wires? Maybe even a battery fuse?
I looked at Home Depot, after market car stereo, and solar equipment providers.
All help appreciated, I am leaving in 2 days.
my RV is the same way, I imagine all of them which have a battery on the tongue are.
those wires are:
1. heavy wire that leads to a DC fuse block inside the RV
2. heavy wire that leads to your 7-way connector for "charging"
3. heavy wire that runs to the battery / fuse
4. lighter wire that runs to your emergency brake switch
5. whatever you added
If you want to clean that mess up, two options. First, undo the twisted together wires, scrape 'em with some pliers, twist 'em together again and use an outdoor burial grade wire nut. The burial grade means it's more protected against moisture, and contains a dielectric grease that prevents the wires from corroding. once you have the nut on there, wrap it with electrical tape to keep the nut from going anywhere. don't worry about the short reduction in wire gauge for the fuse holder. wire resistance is a function of gauge and length, such a short length doesn't much matter.
second option, undo the twisted wires and get rid of the box. scrape the wire ends with pliers and crimp on 5/16th ring terminals - get the good ones from West Marine or Fastenal, not the junk ones from Ace / Home Depot. Next up get nice Bussman marine breaker, 30 amps (or whatever based on the smallest gauge wire connected). One side goes to your battery, put all the other rings on the other side of the breaker. Mount the breaker someplace handy as allowed by your wiring and put some dielectric grease or battery-terminal spray on the terminals.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
