theoldwizard1
Feb 17, 2019Explorer II
Good job. A suggestion for other. The lumber he add is important to reinforce that thin paneling. It would flex and break over time.
I would use a "new work" shallow box, like a Carlon B108B attached to one of those reinforcement piece before it is glued in. Those shallow boxes require short lead so it can be a bit tricky especially if you are in the middle of a daisy chain.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,412 PostsLatest Activity: Jul 15, 2026
