profdant139
Feb 01, 2018Explorer III
Hmmm. I like the idea of somehow tapping into my furnace. We rarely run it, but I bet we will use it a lot more in anything less than 15 degree weather. The only problem is that there is no ducting and no register -- the trailer is so small that the furnace just sits under the counter and blows directly into the room through a metal screen. Not sure how I would divert that airflow.
The advantage, of course, is that we can run the furnace as long as we have propane -- no need for hookups for the heat tape. But of course, the furnace also uses power, so that is not a perfect solution.
Assuming I can figure out how to divert the airflow, I wonder if we can run the furnace while towing, so things don't freeze up while we are on the road? I would imagine that if you are towing at zero degrees Fahrenheit (a likely scenario in the far north), things would freeze up pretty fast while in transit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
