myredracer
Feb 03, 2018Explorer II
They do make light gauge angle steel. They use it for mounting batteries in the A-frame. Not sure where to get it. Our local steel supplier had no sources. It looks like around 14 +/- gauge. I have some I cut out of a previous TT and it's fairly light. Could always take flat sheet steel and get a metal shop to bend it plus you could make the leg dimensions custom sized as needed. Could also get U or Z shaped pieces made up. Regular 1/8" angle steel is a bit heavy but if you were to calculate the total weight you'd need, may not be much of a factor. Nice thing about steel is that you can weld it if needed while aluminum can cost a fair bit more. I'd hate to see how much stainless would cost!
Pls post pics of the build project as it progresses!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
