profdant139
Feb 07, 2018Explorer III
Good point, Larry! So if I understand it correctly, with your method, the aluminum support rails can go essentially anywhere, since the beam clamps can slide up and down the web on the frame members?
And when you say "bolt the panels together," do you mean the foam panels with the coroplast covers? Or do you use an "underskin" of aluminum sheeting?
Thanks again for all of these tips!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
