colliehauler
May 15, 2019Explorer III
mmccray100 wrote:^^^This is correct.
You cannot use HDMI cable to substitute for Coax from the antenna. HDMI is for High Definition signal from a Cable Box, Blu-Ray or other Digital source. Your Antenna uses only Coax.
As for using the old coax to "fish" new cable from back to front, it's probably not possible. The manuf. likely bundles several cables with zip ties.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
