colliehauler
May 16, 2019Explorer III
Colorado #5 wrote:Are you trying to get a signal with a new digital TV or your old analogy tv? If you are trying your old tv there are no longer channels to receive.
RoyB,
I hadn't thought of using the air ducts as a way to run the length of the RV that is genius. And I hadn't thought of running under either. But this Bluetooth thing sounds interesting. I'm going to do some more looking into that. Do you know if this Bluetooth will also send signal from the antenna as well as the blue-ray?
DFord,
I think I had pushed the little button and the green light was on next to it . I have a picture of it somewhere. If I find it I'll post it. For me the biggest issue is figuring out if I'm even getting a signal. I have the coax connect to the tv and I run an automatic scan and it comes up with NOTHING. Not a single channel. So does that mean I need the antenna higher maybe or a stronger antenna or something? I thought maybe it was because it was old but if you're saying that shouldn't matter than I'm perplexed. You would think I would at least get one channel. or a couple fuzzy channels.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
