SFVdave's avatar
SFVdave
Entry door glass Frosted to Clear online or Quartzsite?
Anyone know if there is a vendor at Quartzsite selling the clear/smoked glass for the entry door, or will I have to buy online. I want tempered and smoked to match the RV. Here's the one online. Ross RV Innovations
  • Local glass shop wanted exact pattern and would send it out for a tempered sheet, cost $50.
  • If you want a window that is tempered an will match your RV windows and frames and as a plus it will open for just a few dollars more you could have a EDWIN
  • JaxDad's avatar
    JaxDad
    Explorer III
    hershey wrote:
    I'm sure the url you provided will give you a good product. You might consider just having it dark tinted by a tinting facility. Should be a lot cheaper and give same results....I think.....
    Or just go to to Lowe's, Home Depot or any other decent home improvement place and get the film to do it yourself in 15 minutes or less, likely for under $20.
  • I'm sure the url you provided will give you a good product. You might consider just having it dark tinted by a tinting facility. Should be a lot cheaper and give same results....I think.....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
