BarneyS
Jul 11, 2013Nomad
Well I like the eternabond tape option myself and that is what I will go with. One of the fellas at the rv store said use windex to clean with. What did you folks use.
Also where the gutter edge meets the aluminum roof would you run eternabond just past the seam between the gutter and aluminum roof.
One other question, seems like with eternabond all the way around you are going to make a puddle on the roof. Should you leave a couple inch openings to let water out every three or four feet. Or just tape her up tight?
Barney
I used soap and water followed by a wipe over with Acetone. See the instructions recommended by the manufacturer here.
Yes, I would remove the gutter if possible and sandwich the Eternabond between the gutter and the aluminum roofing material. You might find a lot of the screws holding it on very rusty which indicates that water has been in there. The other option is to run it over the edge of the roof and bottom it in the gutter.
No. It will not cause water to pool or puddle on the roof. Most RV roofs have at least a little bit of slope and are not perfectly level. I would not worry about that at all. Even if it did puddle, unless you have a leak it would not make any difference except be a place for mosquitoes to breed. :W
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
