MRUSA
Jul 12, 2013Explorer
My suggestion is to use the Dicor, let it cure, and then put Eternabond OVER the Dicor. The Enternabond is wider than the Dicor will be, so you will have double protection. Because the Dicor will be protected by the Eternabond, this combination should last longer than you do.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
