justALnow
Apr 04, 2020Explorer
justALnow wrote:jjrbus wrote:
Was curious after posting and took a peak.
https://www.pinellaspowerproducts.com/product-category/products-for-other-brand-generators/products-for-champion-3100-3400/
Thanks for the link ... Mine is the Champion digital Hybrid 4000/3500 and uses a different cap than the 3400/3100. Might have to drill and tap the existing cap ...
That's what I ended up doing. The cap is passively vented, so I had to run a bead of silicone around the inner lip so it would create a suction to pull gas from the auxiliary tank. Fired it up and ran it a couple of hours... enough to determine that it was successfully pulling gas from the Aux tank and not just running on what was in the generator tank.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
