nadkaw1957's avatar
nadkaw1957
Exterior light indicator
If you're anything like me, you've gotten up in the morning to discover that you've left your exterior light(s) on all night. And while you might not worry about battery drain with such a small draw, it can be annoying to neighbors.
I had some 12V leds in various colors laying around, so I wired them to the switched side of my light switches and voila.
  • Z-Peller wrote:
    Details on wiring please. Since LED's are on switched hot wire did you have to bring ground wire from somewhere to LED's?
    Yes, you do.
    In my case, both hot and ground were there behind the panel for all the lights. I just tapped into the ground for the cathode side of the LED and attached the anode side to the switched connector on the appropriate switch.
  • Details on wiring please. Since LED's are on switched hot wire did you have to bring ground wire from somewhere to LED's?
  • nineoaks2004 wrote:
    Neat idea, wonder why the manufacturers didn't think of it ?
    It might cost a nickle?
    Another idea is to install lighted switches. I replaced the water heater switches with lighted ones so that I can see at a glance if they are on.
  • Neat idea, wonder why the manufacturers didn't think of it ? Thanks for sharing and happy camping
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
