ander's avatar
ander
extra battery ramble
hi all,
anyone have a creative use for the (originaly placed ) house battery that never gets used?
i have a 94 pleasure way that came with the usual rv/starter house battery charged from the alt or on shore power.
over the past year iv added 200 watts of solar with 2 6volt batteries.. this system is seperate from the stock sys right now and runs everything in the rv. and only recharges from the solar..which works fine.
the original house battery just sits there..charging from the alternator and waiting for me to think up a cool use for it.
i keep thinking ill pull it out to save weight etc. but thats not a big issue.
i had thought of using it as a spare emergency starting battery...but unhooking and replacing or running the big cable back up front killed that idea for now.
and i cant really combine it with the 2 6volts
anyone have a interesting idea for this odd man out? or should i just pull it and use the space for a safe or hideyhole?
enough rambling..thanks
  • Parallel with the GC2 for an additional 80ah or so, it won't hurt a thing. No switches or anything else needed. Keep it simple.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
